IMG_20250613_185254.jpgScreenshot_2025-06-06-14-31-02-512_com.cvtz50.cvtz50.jpgHello Cheesy , in RS Monitor mode, do you can show oil temperature, intake temperature and coolant temperature that shows on cvtz50 app?
Kind Regards
Kind Regards
Alles anzeigenok, really confusing... so I think you maybe have to go to a "Renault Garage", and try to solve with the CAN-Clip, what "edgieee" says...
one last idea - I would try to clear the error-memory, and then reset the "parking aid ECU"... you can do this with PyRen for example...
if you did not try that, yet...
otherwise I don't know anything else that could solve this problem...
except only that BSW remains switched off...
I am sorry, of course it is not funny, if something is not working properly
Hello Cheesy , for this case maybe i'll provide the CAN-Clip for personal use if possible.
by the way, I'm wondering is it possible to activate "Automatic Highbeam" on every Renault Koleos model via ddt4all?
based on this link
Sorry, I also have no other idea...
and I think perhaps the problem is in the "parking aid ECU", or any other component, and not the programming...
but let me know one more thing - the error came suddenly, or what happened before...? has it ever worked properly...?
Hello Cheesy , for this problem case I have a little solution but it needs the Renault Can Clip Software to solve this case.
he said the "trailer" case happens after accidentally jump the car on the highway (Because of the weak structure road in Indonesia) with a fairly heavy load in the rear trunk.
It turns out that tomgembus is Indonesian, and coincidentally, we're also in the same WhatsApp group.
Greetings from Indonesia
Alles anzeigenHello,
I think for sure you can activate the "RS-Monitor", but I am afraid some graphs will not work (properly), and I couldn't find a really matching .txt file with a "datastring" for all the necessary datas... so I created a unique new one for you...
I did my best
so you can try, if you want to...
kind regards
Hello Cheesy , i've already install RS Monitor in my Renault Koleos unit and try datastring you give to me and it seems works normally (idk if the parameter in the rs monitor maybe inaccurate, later i'll figure it out)
thank you so much, I appreciate it.
Hello, Cheesy , is it possible to install and activate Renault RS Monitor on R-Link 2 2017 Renault Koleos with 2.5L 2TR707 engine code?
Software Version is V9 latest version
